BlueWaterBandit
Thread starter- Joined
- Jul 12, 2019
- 13
I have a 2007 Tahoe Q4 with a carbed 4.3 Mercruiser. The boat runs great, fires up, will hit 50+ MPH at WOT, idles well, etc. The issue I have is that occassionally, under hard load, and usually after I've made a long trip, then idled, then it's back under heavy loan, the alarm will sound, which I'm almost positive is the temperature alarm.
I have my impeller replaced every two years, so I know it's not an impeller issue. I talked to my mechanic about this a couple of years ago and he replaced the thermostat, and the problem went away! But then for winterization in fall of 2021 he noticed it was not getting up to operating temp and was instead staying around 140*, so he replaced the thermostat and the boat started doing it again.
I missed most of boating season last year due to an early season ACL tear, and ended up winterizing myself last fall and changed all fluids before putting back in the water this week.
The boat never gets over probably 165* according to the gauge and when the alarm sounds, it's frequently just quick beeps, not usually an extended beep. And again, the temp gauge is showing just over 160* and normal operating temp is right around this range as well.
Do I need the replace the sensor? The boat doesn't seem like it's running too hot from what I can tell. Any help is appreciated.
