Theoutdoorsman
Thread starter- Joined
- Mar 6, 2003
- 681
I have no idea as to how to identify the correct model number on this outboard. These motors were notorious for fading motor plates as I understand. Hopefully someone can help correctly identify the model/year? The current identification plate is beyond legible.
Here are my problems:
1) I am having trouble starting this outboard. Apparently, the enrichment solenoid is bad. I can apply +12v to the lead on the solenoid, and there isn't any response from it. No clicking, no movement ... nothing. I can hold my hand over the carb throat while cranking, and she comes alive pretty quick, and runs like a top. Short of this cold-start issue, I'm fairly happy with it. Starts first crank after warming up. I need to replace that enrichment solenoid. Can anyone help with the part number?
2) Now, for the wiring question. There is a black wire coming off the starter solenoid. It is damaged from an apparent short in the system, probably from someone attempting to short out the solenoid to start the outboard at some point. I can repair that, no problem. My question is, there is a green wire w/white stripe coming out of the wiring harness that is not terminated. Nor can I find another wire from which it may have come disconnected. Can anyone tell me what the purpose of that lead is, and where it might need to be terminated? Perhaps, since everything is running properly, I may just need to tape it off? I'd still like to know its purpose though, if anyone can help.
