Ok, but if my budget falls short of an SEI replacement, what ratio would I need to find in a used unit? I mean what should I search for?0F491312 shows the drive to be a 1995 Stern Drive STANDARD ROTATION ALPHA [1.65:1] Model number 5010165HS, https://www.crowleymarine.com/mercruiser/oem-parts/stern-drive/1995/5010165hs?mdl=OMGONS&q=0F491312
Is there any other engine and Transom assembly serial number too by chance too? Just so you know what you have going on there in Parker.
https://www.nytdrev.dk/serienummer-i-8.html
The prop "looks like" it may be an 18 pitch Rubex by Solas propellers. https://www.rubexprops.com/
same ratio as you have ... 1.65Well, that seal goo was me being in a hurry just to make everything was covered...not very sophisticated I'll admit.
So, now what should I look for in searching for a replacement?View attachment 377088View attachment 377089
Also, here is a photo of the serial tag which includes the engine, SD, and transom #'s...0F491312 shows the drive to be a 1995 Stern Drive STANDARD ROTATION ALPHA [1.65:1] Model number 5010165HS, https://www.crowleymarine.com/mercruiser/oem-parts/stern-drive/1995/5010165hs?mdl=OMGONS&q=0F491312
buy some tools!Greetings, I have a 92 mercruiser 5.7, serial #0c460205, stern drive #0c581330...
So, I ran her quite a few runs up and down the river. I typically am very careful of fluid maintenance, operation maintenance, and safety are my main priorities. No one else takes on those concerns nor should they.
That being said, I neglected my gear lubricant with the exception of topping it off nicely once over the past 12 months.
Well, It had used up quite a bit unbeknownst to me cause I was not in the habit of keeping an eye on it. Last week after buttoning her all up for the spring/summer season, I took her out for a spin and suddenly I lost forward with a song and all I could do was reve her up...in neutral. Anyway got a tow back and pulled the upper gear housing cape and all the gears I can see are just shamefully sheared away!
So now what? I can only imagine what it would cost to have someone rebuild that upper housing (I'm sure I can't afford it) I doubt anyone would want it as is for $1000.00 bucks...I don't know If I can take on such a job. I've done everything else myself (is: carb rebuild, gimble bearing, impellar, shift cable, etc.) Just not sure about such or if is simply beyond my scope of skill..
Any comments or suggestion would be greatly appreciated!
Sincerely, broken down and bummed out.
In theory you can do it your self if you have the merc specific tools ($$), a factory manual, and some decent know how.Ok, got Cha, thank you all for your time and efforts. I now have what I need to go forward...anything else I need to be aware of?
Meanwhile, so disassembling and replacing and shimming the gears with new is something I want to avoid? And is such to costly to pay someone to do for me?
Try it, buy/borrow some props. Have fun within the limits of your setupI'm wondering if an upper unit 1:50 wouldn't be close enough to my 1:65 to be able to compensate via prop pitch adjustment?
Is it possible?
Yes likely 2” down in pitch with a 1.5 will have you at same rpm as a 1.65 with current pitchThanks, no the transom is fine, but moreover, I'm wondering if an upper unit 1:50 wouldn't be close enough to my 1:65 to be able to compensate via prop pitch adjustment?
Is it possible?
Asome!!! I'll try it as soon as I find a 16" prop! Thank you so much!Yes likely 2” down in pitch with a 1.5 will have you at same rpm as a 1.65 with current pitch
Ayuh,......What is the size, pitch on it now,..??So one more thing...would I still a 28" prop?Asome!!! I'll try it as soon as I find a 16" prop! Thank you so much!
