Lost gearage?
dubs283
OK Ney Sayers! I completely swapped my damaged a1 gen 2 with my A1 gen 2 (including bell housing) and wahla!
Don't see anywhere in this thread where someone said you couldn't swap a gen 2 with a gen 2. In fact that is the most pragmatic approach to your initial issue
Unsure of why you also swapped bell housings unless the original didn't have the check valve for the gear lube monitor system in which case you'd need to add the through transom fitting, lines and monitor bottle
Scott06
I thinking it’s a typo and he swapped a gen ONE bell housing and gen ONE drive on which bondo thought he could do with a little head scratching
Be interested to see how the bellows worked out as gen one and two are diff drive bellows
ScottinAZ
hey, if it worked out for him, and the boat doesnt end up at the bottom of the lake, more power to him. :D
Mrzoooom
Yes, it was a typing error..."alpha 1 gen 1"...
The bellows on the "1" clamps on both ends, The "2" uses the ring...
However, the shift shaft on the "2" would not accommodate the "1" shaft footing...somehow it was too long so I swapped bell housings!
Thank you all for your direction and support...
Scott06
good to know it can be done some what easily.
