simplystressed
Thread starter- Joined
- Mar 16, 2009
- 176
Good morning.
Picked up a late 90's Johnson 25hp that appears to have gas going into the oil injection tank. From what I understand, something has failed on the fuel pump/diaphragm which is causing this.
Compression is 90psi on all 3 cylinders cold (don't want to run it until issue fixed), so think the motor is ok.
I want to disable the oil injection and go to premixing the gas/oil myself to avoid future worries.
How do you disconnect the oil injection on this motor? and do I need to get a new fuel pump since the existing one appears to be failing by letting gas into the oil tank?
Thanks
Thanks
