ronn07
Thread starter- Joined
- Jun 5, 2009
- 38
Motor is a 2000 Yamaha 90 HP 2 stroke. Oil tank has been removed and I mix oil and gas to a 50:1 ratio.
We took the boat out last weekend and had an issue come up with the alarm in the control box.
Right after launching the alarm goes off, mind you this is Minutes into the boat running. I pulled the cowling and touched the motor - cold. Water was 53 degrees so overheating that fast is very unlikely. While the alarm is going off, the motor goes into limp mode.
I figured out if I Kill the motor, and restart with a high idle for about 20 to 30 seconds, the alarm goes off, and the motor runs fine, until we slow down again.
I am thinking it's the impeller or a blockage which I plan on replacing this weekend. The tell tail never stopped and the boat never actually got hot. It warmed up to operating temps, but never to the point where I was afraid of damaging the motor.
What else could it be?
Thermostat or pop it valve?
Fuel filter clog? Replacing that this weekend too.
Thanks in advance.
Thanks in advance.
