EZDuzIt
Thread starter- Joined
- Aug 29, 2021
- 61
Just got a new 2 barrel Rochester carb for my 76 Apollo with the Merc 165 L6. I'm blanking if the spacer goes above or below the base gasket. Makes sense to me it would get sandwiched between the base gasket and the carb but I just want to be sure. It's crazy what not installing a spacer or sometimes even a riser properly can do. Please advise or if you have any other pointers while I have the carb off. I have the idle mixture screws two and a half turns out from fully seated. I have the idle speed set to where I can just barely see the slats. Anything else I should be paying attention to? Cheers!
