1999 115hp evinrude ficht
Landshark93
Hey guys I’m having issues with my 115hp evinrude ficht model # E115fpleen
Bought the motor on the cheap with the impression that the #4 injector was the only bad thing but I have everything hooked up engine has spark has good compression everything seems to be working but the engine will not fire not sure what the issue is I have it on a stand not a boat only things that are hooked into the harness are the key switch the oil tank and I use connectors to complete the neutral switch
Engine will not start has spark and good compression and the #4 injector is getting hot for some reason and will not test right on the ev diag the other three are good and also I switch the #4 injector out with a different one bought off eBay and same thing it’s doesn’t test right like the others
Any help would be appreciated
It should start and run on 3 of 4 cylinders.-----Have you primed the oil system ?
The oiling system must be ready and in service before you can start this motor.----And no , mixing oil in the gas does not work in this motor.
Crosbyman
comp ok sparks OK ... now you need fuel
the best way to know if the injectors are spitting gas is to remove a plug ground the plug properly and insert a paper strip inside the cyl. if it does not get wet with fuel the injector is/are not spitting fuel in the cyl and the engine will never start without fuel.
inj #4 may be mecanically defective and EV diag won't show that but the other injectors should work if.... told to do so by the EMM.
injectors should be cooled by the fuel circulating in the injector & VST Getting HOT may be indicative of internal failure or total blockage. Have the injectors been serviced ?? see basic video
check all fuses on PDP
if an alternate injector suffers the same fate control lead wiring or... EMM control may be faulty .
EMM normally fires the injectors with short ground pulses. FICHT works with a 40v main buss to all injectors and the fact the inj.#4 gets hot may also indicate a grounded control lead back to the EMM .
Check the harness or try to poke and twist the inj. control wires in case one is chaffed to ground.
best thing is to read the book for possible causes.
Q.? do you have the book to service your engine ??
Landshark93
Q.? do you have the book to service your engine ?? see manual FICHT -ETEC to assist
https://drive.google.com/file/d/1RL4u9XPQxTEk6lVk-fPcXxd3O9ctuXL3/view?usp=share_link
I will check all this tomorrow I do have the service manual the video you sent seems to be different injectors of some sort I did how ever I bought 4 injectors off of eBay and swapped the #4 out with a different one so you might be onto something with a wiring issue
Crosbyman
yes the ETEC inj. in the video are different from FICHT . The video was to show the basics of inj. cleaning
you are aware that changing injectors requires injector data spec updates to be loaded in the in the EMM otherwise engine damage will most likley happen at higher RPMs
here is a videoe on updating inj. data files for a ETEC suggest you look into this aspect for your FICHT .. to be safe... used inj. should come with a QR file.
Crosbyman
btw... check the VST ...your FICHT it likely has a small conical filter on the return manifold fuel supply from the injectors. it can block/impair fuel flow causing inj. issues ....incl cooling if fuel doe not flow
Even on the 2005 ETEC books they don't show it !!! CAREFULLY remove the hose... The barb VERY BRITTLE $$$$$ use a large wood screw twist it in the cone and pull it out for cleaning or replacement... if full of black crud... high pressure dist. hoses to from injectors needs to be replaced due to internal crumbling .
OnETECs the HP pump also has a small inlet filter .
when done reinstall proper size oieteker (?) clamp no tye wraps!
Landshark93
Right now the service manual I have says my system works on 26volt not 40
The pdp is good
Injectors all have 11.3 volts not cranking engine
The wiring harness look to be in good shape on all 4
26v to injector 1&3- 12.3 volts to pdp fuse
26v to injector 2&4 -12.3volts to pdp fuse
26v to oil injector- 12.3 volts to fuse
All tested with engine cranking
26v to regulator - 12.3 volts
Relays all test good
Questions should they be spitting out 26v with the engine cranking ? Am I using the wrong meter ?
Right now I’m in the middle off removing the ecm to test the stator and will find out how to test the capacitor also
Thanks guys I will start messing with the fuel system once I figure out my voltage problems
Landshark93
And just keep in mind the motor is on a stand not a boat if I am missing some kind of safety precaution for the motor that won’t let it first because I don’t have the proper wires plugged in I am currently using wires to complete the circuit for the neutral safety switch. Thanks
Crosbyman
The FICHT 2002 manual I have access to says 40v as the running voltage and on ETEC it was boosted to 55 v running 30 v key on. looks like your key on to running ratio is similar to more recent FICHT & ETEC
Quite possible the 1999 version ran at lower volts . In any event the operating principle would be the same... ground pulses to fire the injectors . tried the paper stip test ??
assuming nothing logically wrong on the EMM.... a fuel pressure test on the Injector seems necessary. If no fuel reaches injectors not much will happen .
Can you at least check if the HP pump on the VST to "hear" if it spins at all at key on. you can alway try it alone by applying power to it.
FYI on the ETEC user board they frequently refer to Olly's brew as a lubricant to help reduce rusting and binding within the HP pump. It is basically the addition of a bit of oil in the fuel
to help lubricate the pump. On my 2005 75hp that model injects oil in the fuel supply so I do not worry about. In the later versions post 2007-208 they removed the oil li line to the fuel supply. ...Should you do find your HP pump seized up I read it "may" be restored with some soaking in oil to free it up. If they added oiling in pre 2007-8 maybe it was absent in earlier FICHT years.
Landshark93
the FICHT 2002 manual I have access to says 40v as the working voltage and on ETEC it was boosted to 55 v running 30 v key on
Yes should be the same principle right now I’m checking the wiring plugs specifically the letter j purple and white wire it says I need an omc adapter what’s the best way to get a reading on it I have a regular volt meter with the need pin connectors
Crosbyman
if you are talking DVA adapter you can build one your self for a few $
or search google. all it is is a AC rectifier/storage circuit to allow AC peaks to me measured as DC volts
Landshark93
We’ll i pressure tested the fuel pump and got 5 psi next step is to test the lift pump it says to apply 15 psi to pulse nipple do I just pop a little air in there with a compressor?
