theorifice
- Joined
- Feb 15, 2023
- 35
First start on muffs of the season. I was unavailable between the time of haul out and harbor shrinkwrap so had boat winterized by a mechanic prior to winter storage.
The starboard engine started up easily. I noted that there was more white smoke coming out of the exhaust. When I pulled the outdrives for impeller and shift cable work, I noted that there's just the exhaust tube that is open to the drive. Here's a video after engine was warmed up
Starboard drive smoke:
A few other pieces of info:
* hard to start after warmed up. Needed to give some gas. Unsure if this is normal
* Checking the oil after engine warm up showed level higher than the full line. I plan on doing an oil change once we are in the water. I think the last oil change was beginning of last season.
Is this a "normal" amount of smoke?
