Where do I add tilt and trim fluid on a mercury 1982
You add hydraulic fluid to the pump/reservoir in the boat. There is a round head stainless slotted screw near the top of the pump/reservoir, facing up.
Check out the color of the fluid in it, as it could be 5W-30 motor oil (brown) or ATF (red). The pump/reservoir is self bleeding. The cylinders need to be bled manually. One of the other members has the procedure for this. Maybe he will post it.
Jeremiahjohnson365
Thank you so much I had no clue what I was looking for.
