nola mike
- Joined
- Apr 22, 2009
- 5,956
Well, hopefully this is the year of "fun" boat work...
Last year after getting swamped, I had it running decently by the end of the season. Had a shifting problem that I was unable to resolve--too much slop in the lower. Today I swapped a spare lower. Replaced impeller housing and base, pressure tested. Put it back together. Forgot the slinger on drive shaft. Took it apart. Put it back together. Found out I left myself an early spring present last fall and all the drains and hoses were already connected.
Got her fired up with a little difficulty after finding yet *another* corroded connection. This one from my starter to the OP switch. Broken at the starter. I think I'll wire it into my slave solenoid when I fix it, much easier to get to. Shifting smooth on land without adjusting anything, so that's good. I haven't been thrilled with the performance of the 4.3, I feel like I'm leaving power on the table. ASSUMING that we're (nearly) mechanically sound at this point, this year's projects include:
1. Installing an A/F meter so I can tune the carb like a civilized person.
2. New intake manifold? I bought this one when things were scarce. Looking at it again, it looks like a single plane manifold. I can't find a pic of the OEM merc manifold, but wondering if this might be part of the problem? I'd hate to drop a bunch of money and time to replace if it wouldn't make a difference.
3. Maybe clean and wax?
4. Maybe hook up my trim gauge and limit switch to see if they work
