No spark
willlow
I have a 1971 50th anniversary Johnson V4 125 hp out board with no spark I put a new coil on and a rectifier had spark one day and no spark the next day
jimmbo
Welcome to iboats
How did you determine that the Coil and Rectifier were bad?
Here is wiring diagram for you engine, in case you don't have it.
F_R
Check the voltage at pulse pack input (purple) while cranking with starter.
Willyclay
Check the engine wiring harness for deterioration of the insulation. Joe Reeves told me OMC made a change of suppliers in 1968 and your motor could be suffering like mine with multiple shorts/grounds. Good luck!
Check the starter motor to make sure it is not drawing too much power.
Remove flywheel.----Remove distributor cap.----Remove rotor.----Inspect anti reversing spring.----Clean all part and reassemble.----Inspect wee boots on distributor cap.-----Note , the wires are screwed into the distributor cap.----Did you take note of post #5 or disregarded that bit ???
