SJproline24
Thread starter- Joined
- May 7, 2023
- 8
So I have acquired this motor which has been sitting for 13 years. So far I have replaced the following new plugs, new fuel tank, all new fuel lines, removal of vro and went premix with conventional fuel pump, and rebuilt the carbs, new primer selonoid valve and gasket. Replacing ignition switch tomorrow.
Problem— motor ran for 20-30 minutes no issues many times on land with earmuffs. Go to the ramp starts up and runs for ten mins then it shut off. Got it running again and it stayed running to the point I was able to run the motor out to the bay and back prob30-40 mins all stages of throttle(wot, middle and just above idle).seemed to run pretty well imo. Get back to dock sat idling for a few minutes and I shut it off. Would not start back up. Cranks, sometimes fires for a few seconds but won’t stay running long and dies out. Have to advance timing at throttle to get running though.always.
Pulled plugs and saw spark on all three cylinders. At a loss of where to go now.
Any advice on what direction to take or what to look at.
Greatly appreciate any advice. Thanks.
