73 Dolphin
Thread starter- Joined
- Oct 8, 2008
- 309
Recently went through the carbs on a 2003 Honda BF50A3.
The mixture screws had those EPA covers on them which seem to allow 1/8 turn adjustment. Well I left them alone and cleaned and reassembled the carbs.
Now running the boat on the water for the first time I'm having issues.
Started off ok then started surging and eventually left me limping home on one cylinder.
I really do not want to pull the carbs again.
Basically I have ignition on cylinder one and three. The middle cylinder is not firing.
It does have good spark and there is fuel in the bowl.
Interestingly after bringing it home I only had spark on the bottom #3 cylinder.
Spraying ether into #1 top woke that one up but #2 just isn't firing.
I read somewhere that I can remove the EPA covers, remove the screws and replace with standard ones. Does anyone know what I need to order to do this?
I really feel that I want to pull the EPA capped screws so I can clean out those passageways in place and try to get all 3 cylinders firing. Then I can get the mixture the best I can and then balance the carbs with a vacuum gauge. TIA.
