Johnson Paint
Beakster
Engine block is ALUMINUM !
ok my mistake. So use that paint for all of it? I guess I need a primer for the plastic bits but the aluminium parts and steel bolts can all be direct to metal?
tphoyt
IMO a good zinc primer on the lower unit is a good idea.
saltchuckmatt
Clean it super good, sand and scuff up the existing paint, marine primer on all bare metal. Then numerous coats of desired marine paint. Clear coat.
Oh, I left our mask it.
Paint, 90 percent prep 10 percent paint.
909
attachment.php
909
The finish is extremely glossy and in my opinion a top coat isn't needed.
Beakster
thanks thats good to know....
Should I use a primer when applying to the engine block and/or the lower unit? How about when painting the cowling?
909
Prime bare metal, otherwise scuff the existing paint.
