FLATHEAD
- Joined
- Dec 29, 2002
- 3,880
I did!But did you catch anything?
Right now they have have #14 panhead stainless wood screws. The carriage bolts will work for a temp fix and that’s what I’ll do, but when I redo all the bunks I’ll go back to the screws, lot cleaner look.Get a couple long carriage bolts. Tighten them until the head is below the face of the bunk.
Are you using lags or screws?
You guys are right. It’s only the bunks on the guide ons that have screws. The ones under the boat have lags. My problem is I’ll probably need to cut and carpet the new bunks ahead of time then swap them out after I launch the boat and tie it off or beach it. I don’t have the option to keep it at a marina. Lags will probably have to do underneath.On the new ones, sink the carriage bolts into the wood then carpet them. Maybe use tee nuts buried in the wood, still better than screws. Screws are not a long term solution in wet conditions IMHO.
