blubber2023
- Joined
- May 11, 2023
- 7
Hello,
I have 1979 Johnson 9.9HP. I installed new water pump, impeller, fuel pump, fuel lines, spark plugs. Carburetor cleaned with repair kit. All seems working fine.
I have single handle throttle. I can not start the engine in neutral. If I push throttle arm, it goes in shift and if i push further, i can start the engine. That means i can start my engine in shift but not in neutral.
I removed the air intake box to have access to the throttle linkage and roller.
If i gently push the roller/throttle linkage with my finger, I can start the engine and it runs in neutral with that gentle push on the roller/throttle linkage. If I remove my finger, engine stops.
It feels like initial position of throttle linkage is not correct. How can I adjust that?
The small screw on the plastic part does not help although its all tightened up.
Notes:
In neutral, throttle cam does not touch roller.
Any ideas?
thank you,
Erhan
Notes:
Any ideas?
thank you,
Erhan
