how does one flush out rust from block?
1975oday22
I took the thermostat cover off and found the thermostat to be rusted . as far as i can tell that rust has gotten into the block. i will be cleaning the theromstat housing and blowing it out to make sure of no debris. how should i clean out the block ? alot of rust came out the drain when i drained it but i want to fully flush it out. no water in oil so i know that there is no problems there. right now i have the lower part of the thermostat housing in vinegar. going to leave it sit for the night. then put in the upper portion.
All marine blocks using raw water cooling have rust in them
However I'd you want to flush it. Mix up some oxalic acid and fill the water jacket up.
Let sit for 3 days.
Flush with water
Repeat
1975oday22
any other product that is actually safe for the environment? ie wildlife and other animals..
rallyart
Well, you could change your engine to a closed cooling system with a heat exchanger. But if you use your boat in a fresh water environment the block is not going to rust our from the raw water cooling system.
I think the suggested antirust treatment was to use on shore and would not, therefore, have any affect on the water or marine environment.
jimmbo
Oxalic Acid isn't Environmentally or Animal unfriendly. It is what makes Rhubarb Leaves Toxic for Humans, but I've seen other Animals eat them. Of course I didn't follow them around, so maybe it did kill them
1975oday22
hence i wont use it as it is toxic . not safe for marine = not safe for domestic pets. thanks for clearing this aspect of it up for me.
1975oday22
ok , so the verdict is, i took my drill and used brass wire spinner. cleaned the thermo casing right up, made 2 of 3 gaskets. and now im done for the night. i will run water through the intake to clean the rest of the rust out. now a question about the riser. should i be taking this off to clean the holes out or do you think the water will be sufficient in going through? and if i do take the riser off, can i use red high temp rv gasket instead of replacing the existing gasket?
briangcc
Another option....Pull the engine, disassemble, take it to an engine rebuilder, and let them dip it for you.
Reassemble with new gaskets/rings/bearings, realign, go boating.
Scott06
get a proper riser gasket as this is a point where if it leaks water will drain back into cylinders
Lou C
can these oxalic acid treatments damage head and intake gaskets?
mike_i
We use oxalic acid in beekeeping, kills mites but does not harm bees.
1975oday22
thats not an option. but thanks for that....
airshot
Everything you do in life will have a negative effect on something...so choose which one you do/ don't want to effect...many if these products are fine if they are handled/ disposed of properly !!
1975oday22
as with everything, however once i am ready to take it out to the driveway , i will then use my pressure washer and some vineger and flush it out that way. thanks for the advice and helpfull guidance. cheers
tpenfield
IIRC, baking soda neutralizes the oxalic acid. I flushed my 7.4L engines with it about 7-8 years ago to purge some internal rust.
Horigan
This! Anytime I use an acid product, I buy a bunch of baking soda, neutralize it, and pour it down the drain.
H20Rat
You know the exhaust from your engine is highly toxic? That is injected directly into the water you are boating in...
Its all about the dose. Almost everything is toxic at a certain level, even a fair amount of everyday food we eat. (tomatos and potatoes in particular) Dilute the acid enough and it is a non-event. In reality, if you dumped it on the pavement and flushed it with a hose, it is going to be well below a toxic level, especially if you mix in some baking soda.
1975oday22
well here is the theromstat body. the gasket you see is is the one i made from gasket maker that i had from a friend of mine. not sure if i have a big enough piece to do the riser but will soon see. as for the rust in the water jacket i will flush it out once i get the boat outside with my pressure washer.
