Throttle Lever Replacement
CapriBX
I have a 2001 Bayliner Capri BX2150. The throttle control lever is the original and kind of looking a little rough. Is there a direct replacement or suggested one?
kenny nunez
If it is a Bayliner it is probably not a genuine Mercury Marine control. Most likely that style is not made anymore. You may have to have it bead blasted and powder coated.
Scott06
Yeah it will be an OEM merc - have never seen parts sold for them so likely you will need controller. After seeing the price I bet your old one looks better. IF it is cosmetic on the handle look at some of the plastic spray paints they have or paint made to restore black plastic car parts like bumpers and hit it with a rattle can
CapriBX
So, this one doesn't have the trailer button..
dave8311
Pretty sure that's a dual function switch.
Press a little for trim, press harder for trailer.
Scott06
As mentioned trailer is the second detent on up button. If you have one with a separate trailer button i doubt its original to the boat. Last boat i had with separate trailer button was a 1991
CapriBX
This is what is on the boat.
dubs283
That is a mercury brand remote control. Guessing commander series, maybe 2000? 3000 is the one to avoid but yours is a good one
The trim system will allow the drivento fully raise by pressing the trailer button pictured. Its mid handle, below the trim switch
If everything is working properly keep it. You're not likely to find a comparable quality remote for very cheap
dave8311
Pretty sure he was asking about replacing his, with this one.
CapriBX
If the one on there is considered good quality, then I’ll just keep it. Maybe grease it up a little inside.
