jitterbug127
- Joined
- Feb 6, 2023
- 658
I bought a motor this week for $50. I didn’t do a compression test like I normally would because I didn’t have my tester. Got it home, had a bunch of acorns/fur under the hood. I even found acorns and fur in the lower unit. Motor turned over and shifted freely. I did a compression test and I was getting 60-70 in both cylinders. My spark tester broke, so I was unable to test for spark. I hooked the electric up to my battery and didn’t have any luck getting it started. I sold the motor due to the low compression/lack of electrical with the starter. Motor was in rough shape to say the least. I sanded the points, put on new spark plugs and changed the impeller. I never actually tired to start the motor. I was wondering what was the lowest compression motor someone should buy? For reference motor was 1972 25 hp electric. Carburetor was also seized up even dumping some 3:1 on it. I sold motor for $150 and thought someone else could probably use it for parts. I unfortunately was unable to have success with this motor.
