CaptainInstructo
Thread starter- Joined
- May 30, 2023
- 3
First timer posting here.
I bought a pontoon boat last year with a 1980’s 90hp T of P on it. It started up well but sputtered a bit last year before finally dying on the last trip out. I did a bunch of work to it last fall and this spring in hopes of reviving it to get out on the water with no luck!
New starter, 2 new ignition coils, new floats, spark plugs, fuel tank, primer bulb but still no luck other then a couple 5 second sputters.
My question is this: When I installed the coils back in, are they wired 1 to 6 from top to bottom along with the spark plug wires or is there another sequence?
I’m hoping to get a rebuild kit for the fuel pump (which looked good when I pulled it apart) but other than that, I am stumped. I pulled all the carbs off and sprayed them the best I could but didn’t tear them down due to a lot of the screws being partially stripped and red locktited.
Any help would be great!
