1969 Glasspar 17' Citation(?)
thompsch
Hi all -
I recently scored a lovely 17' 1969 Glaspar (not sure if it's the Citation or "Flying V 175"). The floor deck is rotten in places, so I've pulled up the "rug" and started hacking away at the plywood underneath. I was expecting to find stringers under there, but instead I've found a) 3/4" ply sitting atop 1/2" ply (with a glass layer in-between), sitting directly on top of foam. Is that expected? Or are there stringers "hidden" in all that foam? I honestly can't tell if the underlayment plywood was just glued to the foam, but I've seen no evidence of fasteners.
Follow-up question: do I need to replace the foam, or will replacing the ply with marine plywood and CSM fiberglass be reasonable?
jbcurt00
That's a reckless 3/4 deck over cosmetic temp fix by someone to hide a bad 1/2in deck.
Likely Full gut & rehab
thompsch
Oh, interesting...so the original deck was just the 1/2" ply with glass (presumably top and bottom)? Should there be stringers somewhere inside that foam, do you think?
tpenfield
Hi all -
I recently scored a lovely 17' 1969 Glaspar. . . I was expecting to find stringers under there, but instead I've found a) 3/4" ply sitting atop 1/2" ply (with a glass layer in-between), sitting directly on top of foam. Is that expected? Or are there stringers "hidden" in all that foam? I honestly can't tell if the underlayment plywood was just glued to the foam, but I've seen no evidence of fasteners.
Looks like fiberglass stringers. May be foam cored.
Yes, it is a good idea to add the foam back in.
Yes.
The deck-over is a common practice by unscrupulous people to sell rotten boats
Your transom and stringers rotted 10 - 15 years before the original floor rotted
Time for a complete rebuild
