jimmbo
- Joined
- May 24, 2004
- 14,688
A 73 115, has, I believe 2 Fuel Pumps in Series, each with 2 chambers. Not complicated and easy to rebuild.
By the Mid 70s the Fuel System consisted of only One Pump, completely redesigned, and for a while was mounted on the Cowl Pan on the Starboard Side, it was later relocated to the Port Crankcase Cover.
The inline 6s got the newer Power Trim System in 1984, Engines from 1966 through 1983 used the Older System that had the Pump and Reservoir in the Boat and Hydraulic Lines going to the Rams outside the Transom Bracket. This design used SAE 20 as the Fluid
The 1984 system was contained completely between the Transom Brackets, and used ATF.
