I have a 2007 Sea Ray purchased a year ago. This is my first boat, I am fairly mechanical but have little experience. My tendency is to tear apart everything and replace everything without a definitive cause. The boat has 24 hours on it since purchased. It has a quite growl when turned tight. I pulled the drive to inspect and had water in the bellows, at least half a gallon. I have inspected the u-j bellows thoroughly. It looks good. Drained the drive lube, it doesn’t look like any water there. The water O-ring was in place. Shift cable bellows looks pretty good, as does the exhaust. The only thing found that I am suspecting is the cause of the intrusion is the gasket is torn. See pic! Asking for opinions, pic is of right side below drive fluid pass through. Would this be in an experienced opinion, be enough to allow this much water? Large O ring looks good but would it stop intrusion from a leak in this area? Thank you for any input!
