ScottinAZ
Thread starter- Joined
- Jun 25, 2009
- 865
not trying to fix an issue per se, but see if what I have is "reasonable" given the combination that I have.
Boat is a 1980 vintage 16' vhull bowrider with a Mercruiser 120 engine, MC-1 drive (1.98 ratio?) prop that is on the boat is unmarked in any way that I can find (nothing under the mount nut, nothing I can see stamped on the outside). Gets up and moves good (IMHO) and tops out between 43-4600 rpm. I do not currently have a speedo on the boat.
The boat came with a couple of "spare" props, one of which was used to break rocks, but is marked as a 17 pitch (didnt bother to run all the numbers, it needs to become beer cans again) the other is a very good condition Michigan Wheel 031024 which works out to a 14.5x17. Since the current on the boat is unmarked, and this one could just have been tossed in the boat at random, does a 14.5x17 seem appropriate for the combo? Not looking for full on barn burner performance, but having a good spare on the shelf is not a bad thing..... if this prop is appropriate(ish)
