Attaboy! Please identify the puller used so I can order one also. Thanks.Bought the right puller...
Maybe clean up inside of damper with a flap wheel to remove burrs and clearance it a littleOriginal motor is stripped and put back in the crate. Started putting things back on rebuild and 2 issues came up.
Oil port below the distributor had a plug installed by the machine shop, WHY we have no idea. Would not be a major problem but the dog turd guy also used some kind of loctite and it won't come out. I used acetylene only and Ox/Axe and no matter what heat was not able to break it free. So we're moving the ECM switch down by the oil sender
Installing the damper on the crank and it's not going easy at all. This is old damper and brank new eagle crank. Removing the damper I had to use the pulled almost the full length just to get it off. A local shop has a pusher so going to try and borrow it
Seemed like from your comments that balancer was more difficult than it should have been to remove. use a flap wheel and die grinder to clean up ID of balancer and open it up hair so it goes on easier. Possible its been on and off before someone may have beat it up…Brand new never been used crank, don't know what a flap wherl should be able to do
www.empireabrasives.com
1-1/2" x 1" x 1/4" Mounted Flap Wheel - 5 Pack
The 1.5 inch diameter by 1 inch wide by ¼ inch shank Mounted Flap Wheel Aluminum Oxide by Black Hawk Abrasives are the ideal choice for polishing, flash removal, light grinding, deburring, scale removal, blending, and graining in small spaces, such as the inside or outside of pipes or tubes.www.empireabrasives.com
use them all the time at work on machine repairs and overhauls when things have some wear or damage.
