Remote Oil Filter
Rsoelter
I have a 2007 220v Supreme with a 5.7 V8 Black Scorpion. What’s a good remote oil filter housing to make changing oil easier?
first, welcome aboard
the question depends on what level of wrench turning skills you have
you can buy the kit from Mercruiser. its complete and its pricy and it mounts the filter to the exhaust
you can buy the parts and make your own kit for about $120 and mount your filter anywhere
that is the route I would go. a 30 psi bypass check valve for the block, a canton oil adapter for the block, an inexpensive transdap dual filter head for the bulkhead and a custom set of -10 lines.
Scott06
If u dont want to piece it together or pay fir oem kit
Rsoelter
Thanks for the info
