rustybronco
Thread starter- Joined
- Oct 24, 2021
- 134
On muffs, at idle, no prop installed.
No history of the boat as I bought it used with a bad outdrive. Outdrive has been overhauled. Lower gears looked great. only the carrier bearing was bad. Replaced it along with the carriers needle bearing and resealed. Upper gears were wiped.
When engaging fwd or reverse you hear the dogs ratcheting for about a second. Kind of like drrr innn kkk then full prop rotation. Is this sound normal operation?
