1985 Century Mustang
- Joined
- Mar 9, 2023
- 603
I have most of the seals gaskets, and the water pump finished in the Alpha One Sterndrive. However I'm stuck, that Dam Retainer Ring/Castle Nut, which locks in the carrier bearing is a real byatch to get off. Reason is, I'm getting a gear oil leak where the prop is. And yes, The locking tab to the retainer nut was freed.
A photo is enclosed...
So far, I have soaked it for a few days with Kroil and have tapped it to get some of the penetrating oil to get into the ring. So far no luck. Tomorrow I will try the MAP Gas Torch and a good breaker bar.
Question: Has anyone had issues with this nut removal, and if you had success, can you please post any pertinent info?. I'd like to do it without destroying the retainer nut. If I have to,, I guess I'll have to.
A. P.
A. P.
