ricodudink
- Joined
- May 23, 2022
- 18
I am in the process of restoring a boat, in the process of which I hung the boat engine in the other day. Then got the engine running but soon heard the sound of the exhaust leaking. Then on further inspection, I noticed that water had entered the engine and especially in the rear cylinder.
Now I read a lot about cracked head or engine block but so I hope the water in the engine came through the cracked head gasket or through the exhaust. What do you guys think what is my chance to fix this?
After removing the spark plug and finding water in the rear cylinder, I also found quite a bit of water at the back of the exhaust.
and indeed the rear exhaust ports were also quite wet. In addition, I noticed a kink in the head gasket.
After removing the head, I indeed found a cracked gasket but not from the rear cylinder.
This is how the cylinder head looks like
View attachment WhatsApp Video 2023-06-11 at 20.45.54.mp4
Running engine before taking it appart.
What would you guys do in this situation?
