2004Trophy2352wa
Thread starter- Joined
- Jun 17, 2023
- 16
I have a 2003 mercruiser 5.0 carborated. It started with my port riser getting warmer then the starboard and the alarm went off then i had replaced the impeller the water circulation pump and the thermostat and the risers were cool again. But the thermostat was hot and still sending an alarm. The risers and manifold's were replaced last year and I am still slightly overheating at the thermostat. The alarm starts to beap around above 2000 rpm then stops beaping once on plain. Manifolds and risers feel cool to touch thermostat housing is hot to touch. Doesn't seem to be a head gasket no water in oil and engine doesn't miss. After I turn it off I let it sit to see if risers are leaking down into cylinders to check if it gets hydro locked but it starts right up. It runs about 175 to 190 when getting ready to plain. At idle 175 on plain 180 185 wich is still to high. Please help I hope you have enough information?
