what is this part and where to get one?
bguy
I have a Sea King 15 HP outboard motor, the plate says "Montgomery Ward, Mode VWR 52118, SER 18X 15** (where ** is another 2 numbers). "
there was something missing below the white reel (which pops up to engage the flywheel, so the pulling start rope will cause the flywheel to turn), I used a coke bottle and it seems to work ok today when I tested. but it is a hit or miss because sometimes it wont come up engaging it. so in the past I have used wrapped a rope around the flywheel directly which can start the motor, but not easily because you have to wrap it each time before another pull.
should I take it to a shop to get the part? or someone knows what this part is called....
thanks to all.
jerryjerry05
Needs a better picture.
The white thing:
GEAR, STARTER PINION
F487674 that's #2 in the picture.
Your pic only shows #2 and there's more that we can't see.
bguy
not sure what is missing but I put this blue ring (coke bottle) 3 years back and it seemed to have helped a bit. I do not remember exactly but I must have seen something broken....I can see 3 is there and 15 because the rope is there and pullable. 12 should be ok since the rope is pulled back.
jerryjerry05
So when you pull the cord it doesn't lift the white thing?
Couple more pics from different angles?
bguy
ok thanks. will try to shoot more pics next few days. it does go up about 70% of the time 5 years back. now I tested it seems to go up every time :)
bguy
View attachment 20230619_190529.mp4
I moved it out, hooked it up with gas, put it in a water bucket...tried starting it and bo go. Pulling the rope only turns half a turn of the flywheel it seems. Pulling the flywheel directly gets 3 to 4 turns but also wont start. If I change the gear (n to f and back to n). It will take several pulls to have the.white wheel going up. So definite something wrong.
Nordin
There should be a grove in the Bendix gear #2 (white thing in the pic) where the spring #3 should suit in.
Is the grove still in place or is it gone?
When pulling the cord the spring will make the gear to move up as the spring is hold in place by #4 and the pin #10 will slide in the grove in the gear side.
jerryjerry05
IT's possible the spring inside the starter is broken or has come unwound??
Find a video and see if you can tighten the spring.
bguy
Yes I did find the rope goes back quite slowly or sluggishly. And ro turn the flywheel 3 rotations it would mean I have to pull it out about 5 ft! Something is not right.
bguy
No groove after observing again. This is a video I made again
View attachment 20230620_082505.mp4
bguy
oops video shows on my cell phone but not here on a computer. strange.
tg3690
You can make a Youtube video then post a link to it on here.....
bguy
Is the grove still in place or is it gone?Screenshot_20230620_150821_Chrome.jpg
Yes, there are 2 spiral grooves and that is the mechanism causing the white wheel to go up when the rope is pulled.
Nordin
Yes those groves are for the pin, BUT there should be a grove in the Bendix gear where the spring should suit.
It should be at the bottom of the Bendix gear (under it).
bguy
no. it is rather flat and no sign of anything broken.
Nordin
Check the pic for part number 43-803642T at Crowley Marine.
The spring should slid in and suit in the groove at the bottom of it.
If that groove is gone the gear will not work properly.
In your video it locks like it is working properly !!!!
