paoutdoorsman
Thread starter- Joined
- Dec 13, 2009
- 20
I have a 2002 Mercruiser 5.0 MPI in a Crownline 225BR that just started to have a misfire under load. 409 hours. I've owned the boat since 2009 and have personally serviced it regularly. First time out this year it had a slight vibration, and was extremely down on power while trying to take off/plane. Back in the shop I found 1 plug out of 8 that was fouled. I assumed from the fogging oil during the previous winterization. I replaced all 8 with new 41-993 AC Delco Iridium plugs, and lightly cleaned the distributor and rotor contacts, then went back to the water yesterday. Unfortunately it had the exact same behavior.
Running on the muffs it sounds ok. What would be the most effective way to pinpoint the issue out of the water? The lake is 1.5 hrs away, so it would sure be nice to be able to go back to the water confidently.
