2007 Yamaha F50TLR - Lower Unit Stuck
Mdrye
I’m hoping someone out there can help, I’m stuck. I got this motor for a great deal, too end runs great, knew lower unit needed clutch dog.
While doing the clutch, I decided to do water pump etc, problem is the lower unit is stuck. I assumed it was driveshaft from not being greases. Unit dropped this much easily then stopped? Any help would be greatly appreciated.
wmgeorge
The shift linkage on My F40 TLR had a threaded coupling that had to be unscrewed. On the top left of the picture above where that black tube is sticking out, the piece just above comes off with 2 bolts and you can gain access to that coupling. Just replace the entire pump impeller and outside housing all Yamaha parts around $100 and add a little grease to the splined shaft when putting it back together. The service manual wants you to also use a little marine grease on the impeller.
wmgeorge
My F40 I had apart 3 weeks ago, same year had grease on those splines, was that coupling on the shifting rod. When you get done make sure gearbox is in Neutral as well as the remote lever. Then reinstall that coupling- Got my parts from that place in Denver.
wmgeorge
BTW this has nothing to do with steering, that rod is for Shifting the lower unit.
brodmann
If it's the shifting rod, when you shift from forward/neutral/reverse, the lower unit will probably move up/down. I'm sure that's what it is.
99yam40
the newer ones did not pull up/down to shift, just the old motors.
newer ones twisted back and forth
notice the splines
wmgeorge
Mine is a 2007 built in 10/06, makes no difference if its a coupling it needs to be unscrewed.
99yam40
well did you even look?
the parts breakdown for his 2007 F50 show it does not have a threaded shaft or a nut
wmgeorge
It shows a clip, not sure if that is what is holding it or not? There were some changes to the F50 over the F40, all the 50s seem to have a clip at the bottom and a splined shaft at the top. The 40s never seemed to go that route. Not sure what he has got, when he checks back in we will know.
Mdrye
Can you explain how it unscrews or what u did to replace?
wmgeorge
It looks like its just the F40 the shift linkage travels up / down as apposed to rotate. There is a threaded coupling that holds the two sections together as I described above.
Mdrye
Slow on the reply but I don’t see a nut on there just this
99yam40
simple to look at and see a male and female splined system at that joint.
if that connection is rusted together, it might keep the lower unit from dropping, just like the drive shaft rusting into the crank
wmgeorge
Looks like the one part is brass, is there a clip holding it? How would you take it apart? I have enlarged the JPG and see no splines.
99yam40
look that the parts breakdown, you will see the clip is down inside the lower unit keeping that shaft from coming out of the lower unit.
the 2 shafts are splined at the joint you have in the pic.
the reason you cannot see the splines is they are inside that joint
