wdirnbeck
Thread starter- Joined
- Jun 5, 2022
- 42
Evening all,
I am at the end of my line here. My 1961 Starflite 3 75HP (with unicharger) has been having some issues getting started and running well. It was a boat anchor when I got it from some ol' boys' barn last summer and ended up tearing it all the way down to the powerhead for the next several months. I got the engine freed and cleaned up the guts really well. New rings, honed cylinders, wiring harness, etc. I was throwing parts at it because pretty much everything was f'd.
It never did run well at the end of my time rebuilding last summer and the best I achieved was 2 moments where it started up and ran for all of 1 minute cumulative in a barrel. Compression is 80 PSI in all cylinders which seemed low but since it had fired off for me I went with it. Fast forward to this summer and all signs point to fuel delivery issues. I have spark, the timing is right on, and there is some level of compression so I went into the carb again and really got in that sucker. I took the boat out to the lake today and backed down a desolate ramp to try and test the engine with no luck getting the engine to start. I pulled the boat up getting ready to give up and for the hell of it tried to start it out of the water on level ground and it fired off and ran! I let it go and it did not seem to want to die so I shut it off, put my boat all the way in, and then...nothing. It wouldn't start back up. I was thinking maybe it just wouldn't start at an angle since I had it on the ramp while trying to get it to start up.
Does this still sound like a fuel delivery issue? The engine definitely leaves its telltale mark with the lovely rainbow in the water. Or am I just getting lucky starts due to low compression?
