Ford 460 starter
WingedOctopus
Hello all,
I have a Duckworth with a Berkeley jet. It has a Ford 460 in the dog house. Starter failed so I pulled it to get a part number. It was fairly rusted and the casting numbers are D2AF-11131-DA. It’s mounted by 2 bolts on the passenger side. Obviously the engine (at the pulleys) spins clockwise, does the starter being on the passenger side need to spin CC or CCW . I’m in need of a starter part number. Thanks for the help?
Hello all,
Ayuh,..... I've seen jet boats with the drivers seat on the port, as well as the starboard sides,.....
So,..... which is yer's,..??
Is the starter bolted to the block? Are you saying the motor spins clockwise when you are looking at the front of the motor?
If so, standard marine starter for LH (standard ) motor
kenny nunez
2 sources, Hardin Marine and Arco will have what you need. The main thing is to convert to a PMGR version which uses less amperage but provides more torque.
The main thing that kills jet drive starters is bilge water because the engine is mounted low in the boat and the flywheel spins it into the starter. You have to keep the packing gland adjusted on the front of the pump to prevent too much water from collecting in the bilge.
Which jet do you have, Berkeley, Jacuzzi, Panther ,or Hamilton ?
WingedOctopus
Dang boats. Drivers seat is on the starboard side so the starter is on the drivers side.
WingedOctopus
Berkeley jet. It’s been a great boat.
