Lower unit oil water??
Ronniewhite
I watched u tube can I put 10psi in this and blast that in to check for leaks?
909
Quick silver premium is fine . Their high performance bottle is better. If you're on a limited budget, Walmart's Supertech gear oil will work too.
Ronniewhite
So it's been a month and the oil went back to the color of fresh out of the bottle and no water in the bottom. I have a water pump kit but I'm just going to save it for 4 years from now because I changed the impeller last year.
Oil likely had tinee, tinee air bubbles.----Often mistaken for the dreaded " water in the oil " event.
