jahausbach
Thread starter- Joined
- Jul 25, 2011
- 9
@Nord2903, I just found and read this entire thread. Were you able to find and fix the problem?
forums.iboats.com
I have a 2013 Sea Ray with 5.0l MPI Bravo III and Smart Craft gauge package and the exact same issue. 2000 RPM, low water pressure, guardian mode. I am in my 3rd summer of troubleshooting this with my local Mercury marina. We have replaced the water pressure sensor, sea water pump impeller, sea water pump housing, converted the sea water pickup to thru hull (thinking I had Bravo-itis), the re-circulating water pump, the thermostat, and the water distribution housing. I also had them perform a citric acid flush of the water system after finding quite a bit of oxidation debris while addressing a separate issue with an exhaust flapper valve. Regional Mercury rep has been useless.
4.3L MPI 2007 Searay Sport 185. Single Alarm at 20 RPMs and higher
Good Evening All, Looking for a little help. I am getting a single beep alarm when I am at 20 RPMs in my fuel injected 4.3L 2007 mercruiser engine. Previously I was getting a rough idle and the alarm would also sound at idle, which it is not doing anymore. When the alarm sounds at 20 RPMS...
forums.iboats.com
