Crank but No Start troubleshooting
98 “Fineline/Centurion” direct drive with MerCruiser 5.7 (carb) comp ski motor.
Getting good crank but no start after sitting for winter. It was winterized by a shop.
My gut tells me it’s a fuel delivery issue because it fires with starter fluid. I tested the fuel pump at the connector and it’s only reading 9-10v during crank. Seems low? Either way, I have a new fuel pump on the way.
Anyone have any secrets or maybe obvious things I’m not thinking of? I’ve had this boat for one season with no issues last year.
I appreciate any help thanks!
dubs283
Is the battery good/new?
Could be a connection issue
What ignition system do you have?
Battery is brand new (installed yesterday after I killed my old one trying to get the boat to start)
I’m not sure what ignition system I have or how I’d find that out, but yes it could very well be a bad connection somewhere.
I can’t find the master ground in the boat but that’s on my list.
dubs283
Show us a pic of your setup along with any serial/model numbers you find
First pic is my engine model number. Second is (I think) fuel/oil pressure sensor/switch. Third is my fuel pump. I read 9-10v going to the fuel pump on crank but it seems low. I ordered a new fuel pump but still feel like that’s too low voltage for the pump.
Your serial number 0L006627 shows a TBV ignition, Merc carb and electric fuel pump
You can hot wire the fuel pump to see if it runs but could also be the oil pressure switch, a ground or corrosion
I can’t believe I didn’t think of this. I will try tomorrow and see what happens!
Scott06
View attachment 382524View attachment 382525View attachment 382526
Voltage will drop some during cranking. Are your battery and ground connections clean and tight ? Is battery in good shape ?
