Straight across spacing?Anyone have a part number for the straight across spacing?
For the bolt holes. Instead of offset.Straight across spacing?
ok, but it won't fit your motorFor the bolt holes. Instead of offset.
Ayuh,..... You can't switch from one pattern starter, to the other,.....Had a starter bolt shear off in the block. The block is set up for offset bolt spacing and straight across bolt spacing. Anyone have a part number for the straight across spacing?
2000 GS PWTR charcoal engine, VP outdrives.
