I need some help and guidance in fixing a continous 2stroke oil leak on my outboard 60hp mercury. It's leaking continously also when engine shut off.
I located the leak to the oil injection pump and it's not the hose connections.
I thought it might be the oring between engine and pump but when I placed out paper underneath it rather seems as leak is closer to the spring/outer part underneath the pump. See attached picture.
So is this worth trying to buy oring or some seal or do I need a new pump?
Is this a common problem with oil leak from the actual injection pump?
Are there more seals and repairs to the pump that can be done?
