Crank Position Sensor
John Shefte
Model MCM 5.7 liter
Serial # 0l029283
1997 Mercruiser 5.7
The motor in this boat has been replaced before. I am installing a new long block. Both engines had a crank position sensor on them. There are no wires on the wiring harness for the sensor and none in the boat. This is NOT a fuel-injected engine. Is the sensor needed on a carbureted engine? I did not take the engine out, so I do not know if it was even hooked up on the last engine.
It's a truck motor with truck front cover with a carb
The crank sensor is just a glorified oil plug
