Help with cooling my 1985 70hp evinrude
captain wantabe
Just picked up this engine got it running and noticed it doesn't have a tell-tale. Was wondering if someone could give me advice on how to install one
Well-----The 1985 models had a tell tale installed at the factory !!---So is this motor a 1985 ??----Post the model # or pictures of this motor.
That is a 1985 model.----These 70 HP motors have had a tell tale installed at the factory beginning in 1978 !!!!
captain wantabe
Sorry took so long to get back on!one. Life happens.,. Here are the power head photos. From the last picture from Powe head I think my motor is a 77
flyingscott
Kind of a Frankenstein but looks like a early powerhed dropped on the 85 chassis.
jimmbo
Serial and Model #s on the Bracket and on the Powerhead, certainly don't match.
I would be removing the powerhead to make sure that 49 cube block is not installed on a 56 cube midsection.------------No need to look at anything else !!
captain wantabe
Everything lines up perfectly and the motor runs great and shifts perfectly. Only thing I would like help with is where to drill to install for a tell-tale because I don't want to over heat my multi year motor.
Nope----The hood appears to be a 1985 and not the same as a 77 hood.-----You need to check whether the 77 powerhead is properly installed on the 1985 midsection !!--------------Have you tested the overheat warning horn ?----Tell tale just is one way to indicate that water pump is working.-----Does not indicate that motor is cooling properly.
Could also be a 1985 trim / tilt grafted onto a 77 exhaust housing.
captain wantabe
How do I test over heat sensor. The motor doesn't feel hot to touch after 30 minutes of running in a drum.
Follow word for word.----Find the tan wire near top of cylinder head.----Slide the rubber boot to expose metal connecter.----Turn key to " on " at control box.----Touch metal on tan wire to a head bolt.----Horn should sound.
captain wantabe
Spoke to the guy I got motor from he informed me that it is intact a 77 power head and lower section the transom mount was replaced with 85 section to add tilt & trim to the motor. The only reason he got rid of motor was he was given a newer bigger motor.
