Engine making new sound? Can I still use it?
sadams261
I have a boat from 2008, carb rebuilt and new spark plugs this spring. The engine is a 3L 135hp Mercruiser.
Ran fine the first few days this spring. Last week it started making this new unhealthy sound. (Attached, filmed at idle at dock ). Fluid levels are ok
Starts easily but with a bit of an initial pop (like a backfire?)
It’s very inconvenient to get to a mechanic and we are just about to start our cottage vacation. so I’m trying to understand if it is safely usable or fixable without a mechanic?
  • IMG_0392.mov
flashback
You asked if you could still use it, no, not until you find the failure.. check/change all the sparks...
sadams261
All the plugs look the same and replacing them hasn’t helped. Is my next step the distributor cap and cables or something else?
I don’t know what a compression test is so that’s not likely something that I can do!
dave8311
Cap and wires aren't going to fix that.
It sounds like a compression leak, somewhere. If not from the plugs than maybe the exhaust manifold or it's gasket.
Or, is that a metal to metal sound? Hard to tell from the video.
flashback
Yea I would have bet my first born that a spark plug was missing..
What did the plugs look like?
flashback
If they all look like that then I don't see any problem.. but that noise is not good..
Remove all plugs
Disconnect distributor plugs at base of distributor
Move throttle lever to WOT
Connect compression gauge into first cylinder
Crank motor over at least 3 revolutions (a few more is better)
Right down reading
Release pressure from gauge
Remove gauge and move to next cylinder and repeat until all cylinders have been tested
Compression gauge in link, but should be able to get a loaner from local auto parts store
https://www.amazon.com/compression-tester/s?k=compression+tester
Scott06
Its compression related either exhaust manifold gasket leaking or head gasket leaking
did u do a compression test
sadams261
Only that it is beyond my ability and unfortunately it willl be a few weeks until I can get it to a mechanic. Broken just when. I most want to use the boat so I’m frustrated …
