Close on the formula
dubs283
the block has casted 880 between the welch plugs on stbd side. also the casting number above the flywheel ends with 880
dubs283
definitely not vintage to the boat, replaced at one time prior to current ownership
its a labor of love that keeps me outta trouble
dubs283
guessing the cause of this was the reason for the long block r and r20230701_180744.jpg
dubs283
I wanna visit the store where one can acquire this mcm package complete for $500
dubs283
Post #23 shows an exhaust manifold that has suffered a crack.
What was the cause of this crack?
Will this long block have a 14" flywheel w/ one piece rms?
Won't know until you pull it apart
Probably not on the 14"
The heads are non-vortec. My guess not a true "880" motor. Could just be a new block.
And it is casting number 10243880 that makes it an 880 motor, not an 880 cast on the side
If it has a mechanical fuel pump, it's not an 880 motor
dubs283
Good to know. It does have a mechanical pump with the sight glass on the side, no tygon hose to the carb
It is a 12 bolt intake so yep, non vortec. I'm guessing this long block assembly vintage is in between the og 2 piece rms and vortec? 260 crank horsepower? It does scoot on step
I will verify full casting number at some point this weekend
I was told with log style manifolds that freeze cracks are horizontal, heat cracks are vertical. My guess is the original motor got cooked pretty good requiring the long block r and r
dubs283
You guys ever drink orange juice immediately after brushing your teeth?
Yuck
dubs283
A few years back I purchased a 1982 Ford econoline club wagon. 2wd with a 351 windsor. 38k miles original, nice rig
Only major issue I noted was at times it would puke oil out the rms. 2 piece rms being roughly 40 years old. I know what to do now
One summer I decided to pull the motor and give it a reseal, not down to head gaskets but everything else was inspected/replaced
Now I'd never gone this far in depth with a ford engine but I figured I can get by with my knowledge, an mcm vintage manual for specs and local/online part houses. It worked out great
After removing the oil pan and getting eyes on the rms cap/housing I had no idea what I was looking for. When I removed the cap I saw an empty groove where the rms should be. Ford sent this block out with no rms in place, Friday motor
Installed a new rms with anaerobic red silicone and never lost a drop out of the rms again.
dubs283
The number casted into the block above the flywheel, stbd side reads 10243880
dubs283
haven't gone cinderella yet with the mounted package but this is the best photo of the fuel pump setup you'll see today
