kcassells
- Joined
- Oct 16, 2012
- 8,741
So I picked a used atwood 6 gal tank to run engine. I tank expanded on a hot day and seemed to force fuel into the lower carbs. My mech. called it something like "Hydro lock" whereas their is so much pressure locked in the carbs the flywheel will not rotate. Hence starting issues earlier and other mad men things. Pulled plugs on lower 2 carbs and fuel just blew out as I turned the flywheel manually. Another learning curve. Here are some pics. Turn off the sound if you have young ones around.
View attachment hydro poop.MOV
