hello,
I recently bought a starcraft islander with an aluminum hull and it leaks a little. Finally found the source of the leak and there are small cracks in between the rivets right along the port chine, on the bottom side. They mostly go from rivet to rivet, sometimes going up into the chine seam. Total, cracks are about 24" long. I have a few questions, photos are at the bottom.
Question #1: how bad are these cracks? it looks like the boat came down on some rocks as opposed to just falling apart or something. I've had it out a few times and it doesn't leak that much and the cracks aren't getting worse. It looked like the PO had smeared some JB weld on there, but it cracked again so I removed the JB weld with a wire brush.
Question #2: in terms of fixing them, what are my options? I know a patch with full buck rivets is the best option but I really don't have access to the inside of the boat (there is a whole cabinet system and carpet and seats and flooring and everything all in the way). Could I use blind rivets? Or just aluminum and sealant? Or is there something else I could do so I don't have to pull the whole boat apart? Or something I could try "first" and see how long it lasts, and do a more robust fix later if necessary?
Question #3: What about welding or brazing? These cracks are not near the gas tank, but there are right on the chine where two panels meet. I'm worried about melting whatever sealant is in the chine. I think these boats have sealant where two panels overlap, and these cracks are very close to a panel overlap.
Question #4: Any other options that I'm missing? Or things I'm not thinking about?
Thank you. Photos below.
