Mercruiser 4.3 Alpha One problem - loses power
dubs283
You may find an oem fuel line new, maybe
Sierra sells a flexible pressure rated fuel line in 2 lengths that has the correct ends/connections in place. Plug n play
You would need to bend.
Go to local auto parts store and find Break or fuel line with same fittings and close enough length
minj
Oh flexible, that would be so easy. Would you have a link to that or it is standard for mercruiser 4.3 alpha one 4bbl?
minj
Ok! I know someone that has the tool to bend. I should have measured the lenght before leaving the boat!
Could also take the larger nut off the carb where fuel line attaches and take with. This way you can also check fuel line to thread fitting
If I replace the fuel line, does it come premade with the fitting or I have to do it myself (the bending and connectors)?
You have to make it yourself. It's just 3/8 double flare brake line with brass tube nuts
minj
Ok - here is the final update!
Carb filter was the issue. It was dirty/black, blowed in it to see how much pressure it require to release gas and it was stuck a little. Change it for a new one, cut the gas line, created a part of a fuel line with fitting from a brake line, joined the 2 with fuel flexible hose/ 4 clamps.
Started the boat, got out of the water within seconds, no loss of power!
I say thanks to everyone that contributed to my post!
minj
Like dis?
I had that in the fuel water separator. Maybe if I cut open the filter or the carb filter I would find more. I’m wondering why sand would be in there!
minj
Is mostly corn starch from ethanol. Keep farming, America!
I guess that's what it is! That filter appears to have a valve so the gas does not come back. The one I have purchase from GLMmarine does not have it.
dubs283
That has to be the most beat up fuel line connection I've ever seen
Flare wrench, not vise grips folks
minj
:), I can't tell for the filter but thank you for letting me know! I suppose previous owner hasn't changed it in a while...
edit: oh the fuel line, yeah... that hex nut was rounded...
