My boat run slowly. 120HP,2.5L,1989
liusigou
It seems that battery's short for the power. I can start the motor after I charged for 3 hours. Is it possible the alternator was bad? How can I check if the alternator is good or not?
Ayuh,..... When it's running, you should see 13.6 to 14 volts,.....
You need another motor, rather than wasting time, 'n money on this one,.....
liusigou
I got 14.30 when motor is running at the speed of 1500rpm and even idle, it should be ok
liusigou
I think the reason of my motor shut off in the lake was shortage of the battery's power.
