mdaddy
Thread starter- Joined
- May 16, 2019
- 65
I'm searching for oem camshaft specs. (lift, duration, etc...) for my engine, a 2008 Mercruiser 5.0L vortec TKS engine, 2bbl carb (serial#:1A322719). I had to rebuild bottom end (pistons bored to 30 over) due to piston scoring from spark plug debris in #7 cylinder and compromised cam cap/plug. Looking to maximize performance without making overlu aggressive changes. Probably, a stage 1 or 2 cam, new valve springs, and maybe even a high performance 2 bbl carb. What I don't want to do is lose the original performance which was very adequate (good hole shot, excellent high end speed)! I will happily. re-assemble the eninge with just bottom rebuild to 30 over pistons with everything else staying the same (mild HP incease?). Feedback very welcomed! Thanks!
